All users please be aware that the forum will switch to the new format this weekend (May 2-3 2026). You will see some changes in font and color and location of posts but basic functions should remain the same. Please post to the Help category if you experience issues.
Thanks
qhumberd
Moderator
Thanks
qhumberd
Moderator
Replace jack wheel with a jack foot/plate?
justwood
Member Posts: 13
I have a 2015 T@B U Max and it has a Jack Wheel and moves around more than I am comfortable with. I would like to replace the jack wheel with a jack foot/plate (not sure of the proper term). Can some one recommend one that will work good and not rust in one season that will fit the stock jack?
Camping World sells one, in fact it is on sale right now for less than $9.00. It has 5, 5 star ratings and good up to 2000lbs. Look on their web site for it. Item #18017.The HobbiT@B, 2015-L, towed by a2014 RAM C/V
Thank you, that is exactly what I was looking for. I found the same item on amazon.com a few cents cheaper after shipping.
Is it okay to leave the jack foot on while driving?2017 white/black trim T@B Outback; 2017 white Subaru Outback; Seattle
We do. It reduces the ground clearance at that point by maybe an eighth of an inch.Seaduster said:Is it okay to leave the jack foot on while driving?John and Henrietta, Late 2016 T@B S Max in Western New York -
The big advantage that caused us to install a "jack plate" was that when leveling the camper in uneven sites we found that with the wheel sometimes you could not lower the front of the camper far enough. You gain a few inches in lowering with the plate. In the reverse situation where you need the height, I carry a few short 1" boards to put under the plate to gain height back.
While you lose easy movement by using it instead of a wheel, the T@B is light enough that two people can grab the handles and move it in most hitching situations. Also, as Photomom mentioned, you can leave it installed while traveling and lose very little ground clearance and avoid the hassle of removing/installing the wheel unit at every camp setup.
Fergie
I will not talk about the good and the bad of wheel/vs foot plate, it is a personnal preference.
but curious, when you say it moves a lot,mdo you used wheel chuck, 4 of them?2017 T@G Max Outback "Le Refuge"
TV 2005 jeep TJ unlimited
Alaskan Malamuthe on board!
Les Escoumins and Petite-Riviere-St-Francois QC -
We have both. We keep them in the tongue box. We use whichever works best for the site but the wheel gets more use than the foot.2014 T@b S Max AKA T@dpole
We travel wih our wheel in place. We have the removable jack post that can come off as needed if we are unable to clear our rear van door.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
We just got a footplate & think it might be more useful to us leaving it on all the time instead of having to carry a separate piece of wood or the wheel. Can't say we've ever used the wheel, but will carry it in case we need it..-Brian in Chester, Virginia
I use the wheel...tow with it off, set the trailer without it on(LEGO or piece of wood under). This way, if I need to roll it, I have it, otherwise, nice & stable while in camp...TV- '16 Chevy Colorado LT Crew Cab-DuraMax
2018 320S Outback -
Jack foot is great! Much lighter than wheel. Can leave it on all the time. T@B is light enough that you can still maneuver the tongue by hand.2017 T@B Max-S, silver & silver, towed by a Titanium Silver 2018 Kia Sorento AWD V-6, Twin Cities MN
- 15 "FOR SALE" - New/Used Trailers
- 135 Help - Computer & System
- 915 Introductions
- 72 Teardrop Groups & Links
- 913 Tips & Tricks
