Tada hot water solution
Luke_B
Member Posts: 5
I imagine this has to come with the disclaimer that I am not recommending anyone do this, but this is a solution that worked for me. When I took over by t@da from my Dad he had not properly winterized the camper and a number of things had been cracked due to freezing including the hot water tank which woud have been more than $1000 to fix. I didn't even like the idea of the tiny hot water tank anyways so I ripped it out and installed something similar to the Camp Chef tank-less on demand hot water heater. The installation was about $200. I have had it for several years now and it works really well. The unit does have the tendency to heat up gradually so there is a need to start mixing in cold water mid shower but it otherwise
works well.
works well. Comments
To solve the heat problem I installed cement board that they sometimes use in bathrooms, there is one board on the side you don't really need but the one over top is definitely necessary.
- 919 Introductions
- 74 Teardrop Groups & Links
