I've searched, but I haven't seen this come up before. When I had my 7-pin connector wired, I asked them to wire the 12v power lead so that I could charge the T@B while driving (a 2018 320S Boondock, if that matters). When I have the battery disconnect switch set to green so that I'm charging, my tow vehicle engine keeps running after I shut off the ignition switch! Since it shuts off when I turn the battery disconnect switch to red, I assume they did something funky in the wiring and that the T@B battery is supplying power to my vehicle to keep the spark plugs firing. Since I know nothing of 12v wiring, anybody have any ideas what they might have done? I'll bring it back to the RV place that wired the 7-pin, but would like to have some info on what might be wrong. Thanks!
0 ·
https://www.etrailer.com/question-60402.html
