controller for brakes
Papa
Member Posts: 27
my t@b has a requirement of abrake controller.
california law for this weight trailer.
im new to this technology
any comments on its usefullness.
thanks
thanks
There is a ton of information on brake controllers here on the forum. Use the search function above and it will bring in a wealth of information. There is a great wireless brake controller out there that you can mount to the trailer frame and is one that I used personally and loved, the Tekonsha Prodigy controller. It is a great unit, I know there is information and photos available on the forum and you should be able to easily locate it via the search function above.
Goid luck!Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ1 -
Papa, different states have different requirements for brakes based on weight. You must have a brake controller in your TV when your trailer has electric brakes. Either wired or wireless RF. https://www.curtmfg.com/trailer-brakes-controllers
Have you had a charge line placed yet? If not, and you elect to have a wired brake controller, you can place them at the same time. You need to figure out which controller you want before the install. Etrailer is helpful.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1 -
@Papa what is your tow vehical? It may have one built in from the factory. You may in the least have the wiring harness partially installed from the factory to a 4 or 7 pin trailer connector in the rear. Once determined, and if a controller is necessary, take the unit and your truck to a good mechanic. They’ll know what to do with it. But for your FYI, you’ll need battery to the trailer for brakes AND battery charging. These functions are accounted for in a 7 pin wire harness, and your t@b has these wired for. Your truck needs to match.TV- '16 Chevy Colorado LT Crew Cab-DuraMax
2018 320S Outback0
- 410 Looking to purchase a trailer?
- 427 Service/Maintenance & Recall Notices
