cs model bed size
Papa
Member Posts: 27
any ideas on how to sleep on smaller bed size compared to s model
@Papa, welcome to the forum.2017 t@b sofitel(Dr@gonsFly)TV 2015 Silverado 2500hd(Behemoth). Wyandotte, Michigan.
Draco dormiens numquam titilandus.0 -
We bought the cs-s and know we have to decide to make and unmake the bed every day
we will sleep wheel to wheel. A little different. From our t@g
If you sit outside or in a screenhouse or attached tent, just leave the bed made up. If you have a heavy foam pad, there isn't really anywhere in a CS to move it out of the way. We use a thinner, but comfortable mattress pad sandwiched inside a duvet as a base. It folds up easily and can be placed on part of one of the benches.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1
We sleep wheel to wheel, use sheets and blankets, and leave the bed made unless circumstances arise where we have to take it down. Hubby calls the T@b his warm, dry bed... And we do everything else outside. Have taken bed down and put table up when it was pouring rain and when insects unbearable.2016 T@B CS-S silver with white trim and WSU themed
@Papa
At 6'0" and 5'4" we spent 700 nights in our CS. We'd moved up from a Silver Shadow, similar to your T@G. We decided quickly to replace the table with slats and replace the cushions with custom made mattresses. We created a bed more comfortable than the one at our house! We essentially used the cabin of the CS as our bedroom. With some creativity we could convert it to a sofa/lounge for reading or watching TV. The rest of our living was outdoors. If our stay was multi-day we would put up an awning or screen room attached to the keder rail on the side of the T@B and sometimes a 10x10 canopy over the kitchen. We'd furnish those areas with rugs, chairs, and tables creating living and dining areas.
Hope this helps! May you have many wonderful adventures in your T@B-CS.Steve and Karen Cullowhee, North Carolina 2008 Ford F150 --2018 T@B 4001
