I really want to get and install the Camco Aero-Flo RV vent but after watching the installation video on etrailer and looking at the exploded view diagram in the Fantastic Fan booklet, I'm a little afraid of drilling into the flange on the fan for fear of drilling into the components. Also of voiding the fan's two year warranty. Can I unscrew the visible screws from below and lower the guts of the fan during installation so I can see where I'm drilling? Any advise would be appreciated. We have a 2017 320S if that makes any difference. Maybe older models had different fans?
Earl & Sue | Central NY |
2017 T@B 320S | TV: Chevy Silverado
1 ·
Here it is, all installed. I'm pretty happy with it although I think I'll move it aft a little bit. After attaching the dome, I found that my fan vent might open a bit farther if the unit was moved back another inch. No problem since they give you the slotted holes for adjustment.
When you slip the frame over the fan unit and try to mark the hole for the screws, it helps a lot to add a small piece of adhesive tape to the flange so you can see your marks.
Just as a precaution add a little of that adhesive tape to your drill bit marking the length of the screw. If you didn't hit any wires drilling up to this point, your screws won't do any damage either.
If anyone has considered this mod and been putting it off my advice is DO IT NOW.
Beside the benefit of leaving the vent open, even in pouring rain, it's also preventive in nature -- for nature.
We run the fan in exhaust mode during a wet bath then reverse it afterwards to help dry things out with shower door propped open. When you run the fan in intake mode you've probably noticed insects collect on the screen. Some stuck alive below the blades with dead ones fluttering on the screen from the breeze. This creates a death trap for bird species that flit about eaves and nooks looking for insects. The whirring blades are invisible.
Before we installed our vent cover a Carolina Wren had the unfortunate experience of death by Fantastic Fan. Nuff said.
Urbana, MD
Alan & Patty
Southern Az
