This image has been resized to fit in the page. Click to enlarge.
LED Light bulb from Amazon: 1156 Amber LED Bulbs
Socket is available here: Single Contact Bayonet Base Socket
Note - The above items can be found online at places like Amazon, etc. or possibly at your local auto parts store.
Installation Instructions
1. Remove cover on side "porch" light.
(a.) Install some painters tape around area between chrome cover and clear lens to protect trailer paint.
(b.) Use a thin screwdriver (lower right-hand corner) between chrome cover and clear lens to gently pry up on chrome cover upwards and remove the cover from side tabs (see "tabs" in lower photo).
(c.) Remove (4) screws and remove plastic lens cover.
2. Remove light reflector & bulb assembly
(a.) Loosen screws as shown below and remove (1) screw from strap that secures wiring.
(b.) Fixture should now be hanging in clear and ready for removal.
3. Cut supply wires to light socket/remove socket screws
(a.) Snip wires off as close as possible on backside of old light assembly.
(b.) Slide white covers up and away from ends of wires.
(c.) Unscrew old screws on light socket and discard old slight & socket (or discard former LED assembly).
4. Fabricate/Refurbish Plastic Light Assembly as follows:
(a.) Using a pair of metal wire snips - carefully snip off old light socket holder just below screw holes.
Note: Fixture should look similar to photo below:
(b.) "Score" (indent with wire snips) new bayonet style socket at point noted in photo below.
Use pliers to grip and hold support arm of new socket, while gently bending bracket (back & forth) to break metal eye off opposite end of socket. Remove the round/threaded piece and discard.
(c.) Splice wires together and slide mesh sleeve covers over splices.
(d.) Re-install deflector and carefully drill a small hole (shown below) through light deflector, position wires and install small tie-strap (see photo below) to secure wires in place.
NOTE: For LED fixtures without a deflector, you could easily fabricate one from a small piece of aluminum or tin.
4. Re-install fabricated mount/light deflector hood, mounting screws and wire strap screws on light mounting plate. Your installation should look similar to photo below. LED light gives off minimal heat so this will not be an issue.
5. Test light (flip switch inside trailer) and re-install clear plastic lens cover onto mounting base plate.
6. Install chrome cover over lens cover and snap into place.
Happy Trails Y'all
I sent this on to the factory to show them that it's an easy fix. I believe that their supplier could make these brackets up as they went from an incandescent light to the current "white" LED light that attracts bugs. With some modifications you now have a light that is useful and will help keep the bugs down. I never used either porch light because of the bug attraction issue. I will use it now and won't feel bad about leaving it on more at night when camping.
I think I understand that, Mike. Thanks. Since I haven't received my socket base yet, I was wondering about the hole and whether it was already there, or if you had to drill it. My previous comment was about how clever it was to use this hole to mount the socket base to the bracket that was already there. Please delete this post if it is incorrect or misleading.
Happy Trails Y'all
I like it dark :-)
Here is an example:
CIPA Amber LED Replacement Bulbs 3157
I did change over to the dual and more subtle white/blue LED galley light that I had a difficult time getting from the factory. Some research has been performed and since the LED lights emit a blue light they are more attracted to these types of lights than the incandescent or sodium styled lights.
I had to do some looking to find the amber colored LED lights and only time will tell how effective the lights are, but they should be better than the white LED colored lights.
Thanks.
Thanks
I'm not an expert on bugs, or anything else, but here's a suggestion regarding an "amber" outside, porch light. There may be a simple way to make the "clear" lens into a translucent amber, red, blue, or whatever.
Hobby shops sell brush-on translucent paints for plastics models. I have brushed it on clear lenses to create amber, or red, blue lenses. Sometimes, I brushed on more than one coat to create a darker look. Unfortunately, I don't remember the manufactures name, but a good hobby supply house should know.
Also, Testors spray paint made "candy" colors, which are essentially translucent colors. Prep inside of plastic lens and apply paint according to paint manufacturers instructions. Testors may also have brush on candy colors. Check with hobby supply.
With either brush on, or spray applications, you may have to use multiple coats (not too thick, or before each coat tacks up) to achieve desired depth of color.
I suggest you get a piece of scrap, clear plastic to experiment with above techniques to see if it gives you desired results!
