Both of the intermediate support screws on the screen door latch side have vibrated out.  No problem, NuCamp sent a replacement aluminum plate with the screws attached (no charge- thank you Elsie). I need to remove the screen door to install the plate and it appears as simple as removing the two corner screws at the top of the door. Is that it? My concern is the small cable that keeps tension on the coil side. Reassurance is appreciated.
                Dennis and Mary Jo
North Carolina
2015 T@b Max Q
0 ·
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
North Carolina
2015 T@b Max Q
MOUSE-KE-T@B
Harvest, AL
MOUSE-KE-T@B
Harvest, AL
