Jensen
Rae
Member Posts: 1
my slightly used 2018 T@B 400 didn’t come with the Jensen card. The radio makes noise all the time. Sounds like a motor running. I need help finding the manual. Can’t make it stop with remote or in unit. No idea how to use it. Thanks.
@Rae I found the Jensen operation manual online, printed out a copy and saved one to my phone for back up. It has lots of good info!2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red
@Rae, you will need to remove the Jenson from the wall to see what model number is on the unit. Then (after you screw it back to the wall) you will be able to look up the manual for the Jenson.Verna, Columbus, IN
Ours (2014/15 T@B) is an AWM965 Jensen...
J.D. & Sue
My 400 has Jensen modal JWM70A and I located it online here:
www.asaelectronics.com
goto "Support" then "Manuals and Guides"
Utah Driven
2019 T@B 400 (Ex 2018 400)
2015 MB GLK 250 Diesel
2018 GMC Canyon Denali Duramax CCSB
I wonder if you can get the model number from blue tooth connection
Mine is AWN968
This looks close to a model listed above
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
