COld Water drain valve
ELK
ELK Member Posts: 213
Should this valve under the stairs be  open or closed for camping? I'm flushing the system and when the pump is on all the water runs out a spout across from the valve....so it's running out under the driver's side.
2015 T@B Max S.  TV: 2015.5 Volvo XC70.
  • DougH
    DougH Member Posts: 1,110
    edited July 2018
    Hi, that sounds like the fresh water tank low point drain.  Only needs to be open when intentionally draining that tank (like during the winterization or sanitization processes)
  • ELK
    thank you
