Finally Made It Home
sabel
Member Posts: 283
Finally picked up the Outback yesterday and made it back home. Everything seems to be working properly but will spend the day playing with things.
As discussed earlier, the only problem so far is the stabilizer jack crank is too short and will have to be lengthened.
Except for visibility out the back of the TV, towing is no worse than towing the 5Wide Little Guy. That's a relief.
I sure love the looks of the Outback.
congrats -
To see behind you swerve to your right slightly and remain in lane. Side mirror will show you what's behind ya.
TV is a 2007 Jeep Liberty. Own 2015 T@B Maxx s/wet-bath white green. St. Clair Shores, MI.
Yep, a low side swerve does the trick - And usually you can see their shadow.
- 953 Air Conditioning & Refrigeration
- 919 Introductions
- 407 Service/Maintenance & Recall Notices
- 74 Teardrop Groups & Links
