Plumbing Resources
ScottGScottG Administrator Posts: 5,428
Diagrams, manuals, and other technical information about T@B Plumbing.
NOTE: Information specific to the Alde boiler is posted separately in its own category.
2015 T@B S
    edited April 2021
    Plumbing Schematic (320S)
    Description: Complete schematic of the T@B supply, DWV, heating, and propane plumbing. Based on a 2015 S model. Note that mixing valves and outdoor showers were not added as standard equipment until later model years.
    EDIT (Oct. 2020): Note that the "check valves" indicated on lines entering and exiting the Alde are apparently NOT check valves but rather just connectors to facilitate the transition between different sizes of PEX tubing. An updated schematic is pending.
    EDIT (Apr. 2021): The component labelled "glycol pressure relief drain" is mislabelled. This is actually the Alde flow assembly, which includes an automatic air bleeder and a non-return (check) valve. The Alde glycol loop is an open system that should not be under any pressure. Yes, an updated schematic is still pending...  ;-)
    Created by:
    ScottG
    Posted by: ScottG
    Disclaimer:
     Resources provided by members are not necessarily endorsed nor approved by nüCamp. Models differ and configurations are subject to change at any time. Use at your own discretion.
    2015 T@B S
    edited April 2021
    Alde Mixing Valves
    Description: nuCamp provided video link and technical bulletins with instructions for adjusting the domestic hot water mixing valve. Mixing valves were installed in T@Bs starting in 2016.
    Added 4/29/2021 Speedfit Thermostatic Mixing Valves installed starting with 2021 models.
    Created by:
    Airstream, nuCamp, Speedfit
    Posted by: Hvtymwiltravel, Michigan_Mike, Ponzi, pthomas745
    Disclaimer:
    Original Mixing Valve Video here:
    https://cloud.nucamprv.com/index.php/s/Z2pHmpFwQpfHoM9
    2015 T@B S
    edited October 2018
    Plumbing Compartment Components (320S)
    Description: Annotated images of valves, drains, and other plumbing structures located in the Alde compartment. Based on a 2018 T@B 320 S.
    Created by: MuttonChops
    Posted by: MuttonChops
    Disclaimer: Resources provided by members are not necessarily endorsed nor approved by nüCamp. Models differ and configurations are subject to change at any time. Use at your own discretion.
    2015 T@B S
    Sharon_is_SAMSharon_is_SAM Administrator Posts: 9,497
    edited October 2022
    Nautilus P3 Water Management System for the TaB 400 models
    Description:  Manufacturer user instructions for this system installed starting with the 2021 model year.
    Created by:  B and B Molders
    Posted by:  Cottonmouth
    Added 12/6/21Nautilus P3 Flow Schematic.  Shows how various valve settings connect to plumbing components.
    Created by:  TomCanada
    Posted by:  Sharon Mathie
    Added 12/6/21:  Nautilus P3 Water Flow Path diagrams in addition to 3 D models and water flow part descriptions.
    Created by:  Muttonchops
    edited December 2022
    Nautilus P 2.5 Water Management System for 2021 and 2022 TaB 320 Models
    (Edit 12/7/22 - Refer to P3 instructions starting with the 2023 model year.)
    Description:  User instructions for this system installed starting with the 2021 model year.
    Added 12/6/21:  Nautilus P 2.5 diagrams detailing handle/valve settings and water flow pathways.
    Updated: 7/7/2022
    Created by:  Brianb
    Posted by Sharon Mathie
    Thetford Cassette Toilet
    Description:  Manual for the Thetford Cassette Toilets starting with the 2021 model year.
    Created by:   Thetford
This discussion has been closed.
