Hi one and all, I am new here and in the process of ordering a new T@B 400 Boondock Lite. For those who have a T@B 400 with the Norcold 2 way refrigerator, how does it perform on hot days? In northern Michigan I routinely deal with humid and 90 - 95 temps. I've not had great luck with smaller 2 way propane/120v refrigerators on hot days so I was wondering how the Norcold works in those conditions? I have tried the search function but wasn't able to answer my question or missed the answer if it's out there, so I appologize in advance if its a redundant question.
TJ
Traverse City/San Diego
0 ·
I do have to set it between 4 and the maximum of 5 to keep it below 40, but it worked, as expected, for 4 days.
2019 T@B 400 BL
2021 Toyota Sequoia 4WD
I’ve actually been living in my T@B 400 since late July and I’m extremely happy with the 2-way. I had electricity mostly through Dec 6, 2018, and only 4 days of electricity since then.
I do like this new breed of 2-way (12V and 110V) fridge. It’s definitely not like the former two way in the clamshell 320’s. Mine is not an energy hog, it keeps a relatively even temp, and there is more room than meets the eye.
2013 Tundra TRD 5.7L
Massachusetts
Massachusetts
From what I can gather, the standard fridge is a 2.7 cu-ft 2-way (120 vac/ 12 vdc) compressor refrigerator and there is an optional 3-way (+ LP absorption fridge) that is somewhat larger but you loose the wardrobe space.
I think I would really like to have the 2-way compressor fridge as LP absorption refrigerators don't work well at high altitudes.
Can anyone point me to some official information on these options? I requested a brochure from nuCamp and all I got back was a dealer referral and the promise of more junk mail.
Considering a 2023 TaB 400 with the full Lithium option,
2022 Jeep Gladiator High Altitude, Tow Package.
(1) The device the man was using is just a simple volt meter calibrated to convert to % of charge. Not the same as a real battery monitor.
(2) No mention of the outdoor and/or indoor temperatures to determine the kind of loading placed on the fridge.
(3) No mention of what the fridge inside temperatures were at any time, so you have no idea of how well the fridge was actually performing.
It seems to me that the recorded run times are way too optimistic. Don't get me wrong, I want that fridge in my 400 should I buy one, but have no expectations of 4 days of battery life when running it.
Massachusetts
