I just received the diamond-plate boxes From Custom Aluminum Boxes and would like to get some ideas on how to fasten these to the platform. I’m nervous about drilling holes into the boxes and I want to get this right the first time. Thank you!
Deb - 2017 T@B U-basic Outback silver/silver D@mselfly
2001 Toyota Tacoma 4WD New Mexico
0 ·
This is what I did but you have to drill holes in your new boxes. Go to the hardware store and get 1-1/4” pipe clamps(4), aluminum bar (approx. 1/8”x 1” x 16") rubber adhesive backed bumpers (8) and round head fasteners and lock nuts & washers (12). The bumpers are to raise the box up around 1/4” from the BD platform so water can dry. Use the pipe clamps to attach the box to the BD loops. When the boxes are positioned with the clamps, from the underside of the BD platform drill a hole slightly bigger than your fastener dia hole in the bottom of the box through the center of the large holes closest to the front of the BD platform. Cut the alum bar in 4” strips and Drill a hole slightly bigger than your fastener dia in the middle of the bar. From inside the box drop a fastener thru the hole you drilled. from the underside use the bar to clamp the box to the platform using the lock nuts.
2018 320S Outback
Odessa, Fl.
2018 320S Outback
Pittsburgh, PA
