What is the metal rail holding the coroplast to the frame?
Does anyone know what this stuff is called and where to purchase?  It holds the plastic underbelly (coroplast) to the metal frame under the T@B.
2016 Outback 320
  • JanandDave
    JanandDave Member Posts: 120
    Hi. It’s called a termination strip. Made from aluminum. It’s used with a rubber roof system to secure the edges on the facia or rake. Menards, here in the Midwest, or any big box store that sells rubber roofing materials should carry them. Don’t know if they come in different sizes.
    2016 T@B 320 Max S  "T@BsentMinded"
    2009 Subaru Outback R 3.0
    2022 Ford Ranger XLT Super Cab
  • Tabaz
    Tabaz Member Posts: 2,420
    Whoa! No wonder the people at Lowe’s and Home Depot couldn’t identify it. Thanks J&D for your help. I’ll contact some roofing folks tomorrow.
    2016 Outback 320
  • Michigan_Mike
    So what happened Frank, did you run over a havelina?  😂🤣😂
  • Tabaz
    Mike - Just cleaning up the underside of the trailer so it doesn't detract from the new diamond plate valve boxes!  I was actually toying with the idea of covering the entire bottom in diamond plate, but sanity returned.
    2016 Outback 320
    ScottG Administrator Posts: 5,696
    Always something to learn on this forum!  :-)
  • gspdx
    gspdx Member Posts: 208
    @Tabaz   I am thinking about replacing the coroplast myself.  But I agree, if sanity prevails I won't.
    Adding tank heaters and would like to add some insulation.  I was thinking a more rigid bottom cover would be a nice upgrade.
    2019 T@B 400 BDL
    PNW
  • Tundra57
    Tundra57 Member Posts: 640
    Can't you just replace the strips with flat aluminum bar from Home Depot?
  • Tabaz
    Tundra57 - I looked into that.  The metal bars are significantly thicker than the factory stuff.  I did find out Lowe's and Home Depot sell the factory strips for about $5 each.  They come in 10' lengths are are dropped shipped to a location of your choosing.
    2016 Outback 320
