Plastic shavings in waterline and screen before pump
tepe50
Member Posts: 37
I was getting ready to winterize a tab 400 and was cleaning out the screen and found this in it and the connection from the tank is plugged up plastic shavings also. If you’re having any water flow problems this may be the culprit and probably not good to be in there anyways so everybody might want to check. 2020 tab 400 BDL & 2013 siver shadow 5x10
I also found some in the pickup line from fresh water tank. It doesn't appear they clear this stuff all out during manufacturering2019 T@B 400 Boondock Lite0
Pretty common in most new RVs.
- Hash T@B Fun
2
