When I opened the hot water drain this year I had water run into the inside compartment on the floor; I closed it quickly and opened the cold water side and it drained fine. Then I opened the hot side again and it drained with very little leak.
i then blew out the lines and more water leaked onto the floor.
I’m guessing the pex fitting is either cracked or is coming loose on the bottom (flooring) side. Has anyone had this problem?
I’m wondering how bad it is to replace. I haven’t taken it apart yet and don’t know how much access there is to the drain through the floor and out the bottom? Any ideas or pics?
