Little round switch on wall next to radio
Geetarz
Member Posts: 18
What the heck is that little black, round switch with the LED when it’s on, on the wall next to the radio for? I could not see a darn thing mentioned in the online material. Thanks!
T@B 400 2020
Some folks add an ON/OFF switch for the radio like that to eliminate battery drain from the Bluetooth.
Rich2019 T@b 400
2025 Toyota Highlander 2.4L TurboBellingham WA -
@Geetarz, looks like you bave a t@b 400. This question has been raised multiple times before. I think it is an auxiliary cooling fan for your fridge. There are pbotos posted on other threads. My presumption is that the switch is mounted above your fridge, and that you have the large 3-way fridge. But.....presumptions can cause problems. Without knowing the year and model of your trailer I can only guess. Might you consider adding that info to your signature line? Hope this helps. -Denise2017 t@b sofitel(Dr@gonsFly)TV 2015 Silverado 2500hd(Behemoth). Wyandotte, Michigan.
Yes, it is above the three-way fridge. It’s a 2020. Thanks! I sure wish this thing came with a manual. I was told by Nücamp they are working on revisions and updates.T@B 400 2020
https://tab-rv.vanillacommunity.com/discussion/comment/116976#Comment_116976@Geetarz Not sure I’ve ever posted a link to another discussion in the year or so I’ve been on this forum, so the above link may or may not work. If not, just do a search for ‘Switch Left of Radio’.Alan & Natalie McKinney, TX
nüCamp: 2019 T@B 400 Boondock Lite
Dream big... work hard... never give up. -
In our 2019 T@b 400 that switch has to be on for the fridge to work in either propane or 12V modes.Dan and Liz 2019 TAB 400 BDL 2010 Toyota Tacoma V6 4WD TRD Sport
- 915 Tips & Tricks
