Help identifying the purpose of this drain line on a 2018 CS-S
mreric
Member Posts: 154
Any expert out there ? I have been using the alde for 3 days.. there's is this drain point that seem to drip out a bit of water. It does not seem to be glycol. What is the purpose of this drain ? The glycol is between the min and the max line. Does the alde expel condensation ? 2018 cs-s. Any help would be appreciated
Do you have a Cool Cat?2016 Outback 320
2024 Ford F150 Supercrew short bed. -
I doubt this tube has anything to do with the Alde. Unless as Scott suggests, it is simply water condensation in the tube itself.2016 Outback 320
That could be the overflow for the Alde glycol reservoir. In CS-S models isn't the tank mounted behind the toilet, right above the drain in the photo? If so, it seems plausible in cool weather that a little condensation could form in the overflow tube and find its way out the drain. Just guessin'...
i have a response from nucamp- see below- thank you to those who responded"Hi Eric,This would be the Alde overfill line. Perfectly normal after driving to have a little fluid splash and drain. The drain is designed to keep fluid from raising above a certain level in the Expansion Tank.
