Refrig door seal
webers3
Member Posts: 435
Opened the refrig door and the whole seal came off, what's up with that? Is is glued on or just pressed into the slot? Thanks in advance
2017 T@B 320S 2019 Jeep Cherokee - Southern Connecticut
Press fit. Common issue especially if you leave the door closed during storage.
When not in use we crack open the door, insert the retainer pin, and leave it slightly open.
If it comes off easily you could add some removable adhesive in the slot.
2015 T@B Max S (White/Silver) -> 2014 Ford Escape 2.0L (turbo, AWD, factory tow) -
Thank you @TabberJohn. I will give it a try
- 916 Introductions
- 72 Teardrop Groups & Links
