Are you using the correct 2 inch ball for towing your 400?
atlasb
Member Posts: 584
A recent article I was reading brought up the question. We have had a lot of discussion about tongue weight etc, but what about the 2 inch Ball. I checked ours and it is the 6000 lb capacity ball. There are a lot of 3000lb balls in the 2 inch class and with the 400, this may not cut it. Our last trip with a light load and no onboard water scaled at 3200lbs for the 400. The weight is stamped in the top surface of the ball in most quality balls.
Thanks for the heads up. I checked my hitch and the ball is rated for 7000#.2018 T@b 400, 200ah Lithium with Solar
2013 Tundra TRD 5.7L
Massachusetts0
