Bump in floor
db_cooper
Member Posts: 748
Has anyone had a bump or horizontal imperfection appear in their floor?
Cleaning up after our latest 1500 mile excursion a in the 320,noticed about a 6 inch long raised area right above the axle area, just in front of the converter. It's not soft, doesn't run under bench area, and I can't find any signs of water intrusion. Appears to be from bouncing as far as I can tell, are there metal cross members under the floor like the walls?
2015 Max S Outback | 2010 Xterra -- Retired
2022 Ford F350 Tremor | 2022 Cirrus 620
@db_cooper, please contact your dealer and ask them to check to see if your floor is “delaminating”. It happens occasionally and if they don’t know what you are talking about, have them contact nüCamp to get an explanation.Verna, Columbus, IN
https://tab-rv.vanillacommunity.com/discussion/7975/what-is-the-t-b-320-floor-made-of-soft-floor
Thanks Verna, but it's a 2015 bought used, so no dealer handy.
I found this post of the construction, so I think I'm feeling an aluminum cross member. We take our Outback on some rough roads, so I think it's most likely from that bouncing. I'll just continue to monitor at this point.
Will be curious to hear of any others with similar issue though.2015 Max S Outback | 2010 Xterra -- Retired
2022 Ford F350 Tremor | 2022 Cirrus 620 -
@db_cooper, actually your 2015 is before the delamination issues became an occasional problem. You can always email tech@nucamprv.com and discuss it with Creed.Verna, Columbus, IN
Verna said:@db_cooper, actually your 2015 is before the delamination issues became an occasional problem. You can always email tech@nucamprv.com and discuss it with Creed.
Looks like I will contact Creed. It appears to be a bubble, possibly just the marmoleum flooring not adhering to the Azdel. I'm not concerned with how it looks, we keep a rug over the area, but if I can, I'd like repair and keep it from spreading.
Greetings. I read your post on this issue with interest and would like to know if you can share what you learned from Creed? I understand this is not a "bubble issue" / de-lamination. Thanks.
2019 TAB 320sVancouver Island
- 916 Introductions
- 72 Teardrop Groups & Links
