FM antenna
zipster
Member Posts: 1
We have a new 2015 T@B Max S and are on our first excursion. Everything is working but our FM reception is poor on some stations. It improves when I touch the metal part below the rubber antenna. Have others experienced this problem? Does this indicate a defective connection between the antenna and radio? Would a better antenna improve reception, and if so, what antenna upgrades have others purchased? Many thanks for your feedback!
I don't think it's the highest quality antenna. Maybe a little tin foil on it would help?
Hmmmmm - First time I've heard a complaint about FM reception. Could be a bad connection (ground?) if it changes when you touch it. Or, you're touch adds your body to the antenna volume. Anyone else in the forums having FM problems?
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
