2018 T@B 400 Fantastic Fan Switcharoo
SeaLaVie
Member Posts: 47
Hello!
Thanks!!
I have a stock "EZ Breeze" fan in the travel trailer bathroom. It appears to use the exact same outer frame with the fan mounting screws in the same place - although I have not taken it apart yet to verify.
I would like to purchase a full package 7350 and use all of the new parts from it except for the outer frame. I want to install the new fan parts into the existing 1250 frame including the new dome vent cover. Anyone know if this is possible?
Then I'd like to install the whole "used" set up from the 1250 fan into the existing EZ Breeze frame, including the 1250 dome cover. Will that be possible?
Thanks!!
2018 T@B 400
yes, it's possible. I had mine switched out at Nucamp because I did not want to have to deal with the switch anymore. I paid for the upgraded fan - same as the one in the main cabin, but it fit perfectly. I just felt I did not have the expertise to do the job right.
Peter and Nicki; Quechee, Vt
2019 Tab 400; 2019 TV Honda Ridgeline0
- 75 Teardrop Groups & Links
- 916 Tips & Tricks
