Fixing the poor radio reception
rh5555
Member Posts: 538
We have a 2020 TAB400 with the Jensen JWM70A radio. I've noticed that the radio is not very good at pulling in weak stations and I sought to improve that deficiency. My first stab at fixing this was to substitute a longer antenna for the supplied one when camping.Sometimes this seemed to work better and sometimes not.
It did seem to work better at night, but I wasn't sure why.
Then, one day, I happened to disconnect the solar panels while using the long antenna and suddenly everything was much improved: Really weak stations were coming in pretty much static free.
I'm using the Victron MPPT 100|30 solar controller which is located next to the ALDE equipment right below the radio. I've tried adding ferrite rings to the cables entering and exiting the controller, but that didn't make any difference.
Has anyone else noticed this interference? I don't know if I have a defective Victron product, defective ferrites, or if I've chosen a bad location for the solar controller. Any other experiences welcome!
P.S. You can turn the Victron controllers on and off using the bluetooth app: look under settings - battery.
Not sure if there are many changes in the current Jensen versus the Jensen AWM968 in our 2015 T@B SMAX or the voltage converter for the camper, but this has been a long term problem, especially for AM reception. Besides our Jensen having very poor RF noise rejection, the converter itself generates a lot of RF noise.
There are many sources of noise in electrical devices these days as manufacturers use noise generating circuitry to minimize power consumption. Good examples are 110 volt LED light bulbs that have a printed circuit power unit in each one to lower the voltage from 110volts AC to the 12volts DC needed by the semiconductor LED's. These circuits use "chopper" techniques to lower voltages without generating heat and thus power. To achieve that these circuits generate RF noise! I have all LED bulbs in our house to save power, but can't get any AM reception inside, but if I go into my car in the driveway they all come in clear!
When camping try to park away from 110volt LED lights on buildings and turn off your converter if you can do without 12volts while on "shore" power. Or like us, just get a good portable AM radio to set on the picnic table at your campground!
See these posts for further discussion of our experience:
https://tab-rv.vanillacommunity.com/discussion/3683/am-reception-on-the-jensen-awm968#latest
Good Luck!
Fergie
We have a 2018 Tab 320 Sofitel purchasing it used in April of this year. Only one local radio station was strong and I looked to improve the reception of the Jensen JWM70A.
After trying some after-market antenna I purchased one from Germany with a booster that was made for Renault and Citroen cars. A bit of bear to mount it but it's much improve especially if I bring the antenna itself from being tight on the trailer body. I also lined the area behind the JWM70A with tin foil as I noticed a 120v receptacle was in close proximity. I also dissembled the pitiful antenna that came with it and found a lot of rust and corrosion internally. Explained why I had such poor reception to start.
Can't say I'm impressed with the JWM70A bluetooth capability to sync with my iPhone.
I also swapped out the stock speakers with an upgrade and it's 300% better to my ears.0 -
Just a quick search points to a big problem with radio frequency interference from solar controllers. An interesting experiment would be to disconnect the solar controller to see if the bluetooth performance of the Jensen improves.
Interesting observations, @rh5555 & @Fergie.
I also want to try @grc's tip about the aluminum foil around the Jensen.
I've tried several ways of upgrading reception, but my most recent antenna upgrade seems to be the best yet, using a Jensen amplified marine antenna. See my writeup here..
https://tab-rv.vanillacommunity.com/discussion/comment/127687#Comment_127687
I still feel like there's no hope for AM radio, but maybe I just haven't learned the secret yet. Also, mine hasn't really been tested yet with our solar system connected & running. I also haven't noticed whether the converter or AC powered LEDs cause interference, but will test that next time.-Brian in Chester, Virginia
Using Bluetooth we connect our phone apps to the Jensen system & stream news, sports, Pandora, etc.2018 T@B CS-S on an Outback axle
2017 Toyota Tacoma with tow package
Pacific Northwest0 -
I"ve had a few issues paring Bluetooth but have found that to start with you should "forget" the Jensen in your smart phone and forget your smart phone in the Jensen. Turn off Bluetooth on your phone, turn off the Jensern, then turn both back on. Clean slate.
Then, push and release the "Bluetooth" button, then press and hold it to pair with your phone. Since doing this the Jensen has recognized my phone every time.
Hope it works for you!
San Diego, CA
www.airbossone.com
https://fineartamerica.com/profiles/owen-ashurst/shop0
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
