Maintenance kit
Kentsb
I was reading the Nucamp manual that you can download from their website. In the manual it makes reference to a maintenance kit. My dealer gave me a starter kit but I don’t think that is the same thing. Is the 320 supposed to have a kit? I am hoping that it comes with a screwdriver to fit the square screws for the license plate. Maybe more that I am not aware of.
52 nights
I don’t remember reference to a maintenance kit, but mine definitely did not come with one. The square drive screwdrivers are available at pretty much any hardware store, I added them to a basic toolkit I put together, and bought spare fuses for everything listed in the Fuses for Newbies thread here on the forum. The square head screws are used everywhere on the trailer, so you definitely need those drivers.2019 320s BD Lite, white with blue (“Haven”)
Pacific NW0 -
@VictoriaP They’re #1 & #2, right?John, Judi, Guinness & OD in PDX
I ended up with S1, S2, and S3 because they came in a set, but I don’t think I’ve ever used the S3.jgram2 said:@VictoriaP They’re #1 & #2, right?
Edit: looking back, @Verna says it’s 2 and 3 that are used. Hmmm...2019 320s BD Lite, white with blue (“Haven”)
Pacific NW0 -
Correct that to be #1 & #2.I never found any #3’s on my 400, but I had a couple of #3’s on my 2014 T@B S Max.Verna, Columbus, IN
On page 48 of the manual is the following “ A set of screw drivers in your maintenance kit will come in handy to adjust these”. Under the topic of Hardware Adjustments.
52 nights0 -
@Kentsb, no maintenance kit comes with any new nüCamp camper. The camper will have a wrench for the stabilizers and the tire lowering mechanism , if it is equipped with one.There are many posts here on the forum that give suggestions as to what an owner should have on their tool kit. The first item is normally the appropriate sized Robertson or square drive screw drivers.Verna, Columbus, IN
I think the manual is suggesting you put screwdrivers in your self created tool kit. Over time you will find your tool kit will grow. Though they are suggesting, I agree it implies the kit is provided. Semantics. My kit seems to grow every trip...
2016 cs-s max0 -
@Kentsb...as I was also reading the manual last night...lol..I believe they were just suggesting what you should have with you while travelling...and yes they missed the "wonderful" Robertson screwdrivers #1 and #2... Zip ties always travel with us!...Happy reading...!Former 2017 T@G Max XL
2021 T@B Boondock CS-S
2018 Nissan Pathfinder
Ontario, Canada1 -
As to the Robertson or Square screwdrivers ... I am notorious in our family for being incompetent with screws. I found a fantastic set of Robertson/Square drivers (sizes 1, 2, 3) from Tekton on Amazon. The handles are fantastic, ergonomic and provide great torque -- worked better than my battery powered driver for replacing the screws! I think I might replace all my screwdrivers with similar ones. This set of 3 was $14.55 on Amazon.
https://www.tekton.com/square-high-torque-screwdriver-sets?quantity=1&blade-finish=chrome
2018 T@B 320 S Boondock | 2015.5 Volvo XC60 T6 AWD | Seattle, WA, USA
"Blessed are the curious, for they shall have adventures.”― Lovelle Drachman1 -
If you have a Harbor Freight nearby, they have this set of 6 bits for $2.79
This bit set gives you three lengths to reach square drive fasteners. Use with a drill-driver or 1/4 in. driver handle.
- Sizes: #1, #2
- Precision tolerance S2 alloy steel construction
- Bit length:
Tampa FL0
- 144 Events & News
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
