Air8 will not run off of a 15 amp circuit
jkjenn
Member Posts: 6,425
As an FYI, the Air8 will not run off of a 15 amp circuit.
The good news is that is I now have family planning to install a 30 amp conmection as a part of their imminent electrical box upgrade and rewiting project.
The 30 amp plug was being installed in the pole barn...thanks for the info..Former 2017 T@G Max XL
2021 T@B Boondock CS-S
2018 Nissan Pathfinder
Ontario, Canada1 -
That surprises me. I can run my coolcat off a 15amp...and I thought the Air8 used significantly less energy.jkjenn said:As an FYI, the Air8 will not run off of a 15 amp circuit.2025 T@B 400 Boondock Black Canyon with 400Ah Battle Born and Victron Multiplus 3000
No kidding!! Water is doable....sewer...we'll need to work on that. There doesn't appear to be a sewer cleanup anywhere on site. BUT, since the live in Ohio, the turnpike has free dumpstations every other exit, which makes it easy to dunp on my way home.TNOutback said:
Since they are installing you a 30A service @jkjenn, ask for water and sewer connections while they are at it!
