Bed Extension for T@B 320-CS
JP2558
Member Posts: 244
Here’s my solution for our 2018 320-CS. I’m 6’2” and 200 pounds. Over
the last 362 days we’ve made several attempts to find the perfect
solution, but this is the final product. Below you see
three slats, and the support leg. At the bottom is where the leg
attaches/screws into the main slat. This is storage/transport mode. When
ready to deploy, simply remove the wing nut in the center enough to
allow both slats to rotate 90 degrees.
Next is the view after the wing nut has been removed allowing both slats to deploy to 90 degrees.
Below
we see the slats pre-positioned, with the two slats open to 90 degrees
sliding onto the cushions, but under the two or four inch mattress
topper/memory foam. I intend to cover the ends of the slats with some
material that will lessen the chance of the edges of the slats damaging
the cushions or memory foam.
Below is the finished
product with two couch cushions off the hide-a-bed from our basement.
This is proof of concept, but we intend to to visit an upholstery shop
and get some custom cushions made. In the lower right you can almost see
the support leg under the corner of the cushion. This allows me to
sleep at an angle and I can now stretch my legs with room to spare and
have my head lower in the bed than my wife’s head! I also no longer fear falling off the bed!
Here’s a better view of the support leg. It’s very sturdy. I weigh 200 pounds and can sit on this without fear of collapse.
Thanks, Jerry
- 75 Teardrop Groups & Links
- 916 Tips & Tricks
