Winterizing in New England
Bonalexander
Member Posts: 26
This is my first season owning my 2018 T@b 320s and I live in Massachusetts. Wondering what everyone’s experiences are winterizing their campers. Do you use antifreeze or do you simply blowout the lines? Any pros/cons you’ve come across with either method?
I have used both ways with success. Most recently used antifreeze. Either way not overly difficult. Antifreeze does give me a little more peace of mind.2016 cs-s max
Three years of blowing out the lines in CT. Little effort, minimal special equipment and no need to de-winterize, ie flush out the antifreeze.2017 T@B 320S 2019 Jeep Cherokee - Southern Connecticut
There are a few folks who have had issues with water left in key areas (exterior shower wand and toilet plumbing). I think if you really blow out the lines thoroughly, make sure that includes the toilet and exterior shower, then you will be fine.
This will help.
Drain, blow and fill - one way to winterize your T@B with Alde system 2019.pdfSharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio -
@nhmike @webers3 @Sharon_is_SAM
Thanks all! I do have the pressure item shown in the PDF file so will give it a try and see how I feel afterwards 🙃
