Retractable screen door is awesome!
twocutestwocutes Member Posts: 198
edited June 2015 in Trailer & Towing
I want one.  I dropped of the T@B for warranty work today at the dealer and saw a newer model with the retractable screen door, instead of the less than ideal Velcro screen.  I thought I read about it on another thread, but don't remember which.  The frame its in looks like it could be installed on the older T@Bs.  Does anyone know?
Beth
Minnesota
Practicing to be a wanderer
2020 T@B 320 CSS Boondock Lite
2014 T@B 320 CSS M@xx
2020 Jeep Wrangler Unlimited 8 speed automatic
2020 Jeep Grand Cherokee Limited V8
2018 Jeep Wrangler Unlimited Rubicon 6 speed manual
    Someone installed one - If I remember correctly they had to shorten the cabinet door under the fridge.
  • twocutestwocutes Member Posts: 198
    Thanks.  I'm thinking if I emailed the Parts department, they could tell me if it would work in the clamshell (no frig inside).
    Beth
    Minnesota
  • CyclonicCyclonic Member Posts: 1,232
    Depending on the layout of your T@B you may have to make some modifications to the cabinets. I was able to install one in my 2012 with no modifications.
    Sterling, VA
    Beth, I read yesterday that someone moved their cabinet doors over a bit, rather than cut 5/8" off of their cabinet door. Keep that in mind if you're told to trim a cabinet door.
