Retractable screen door is awesome!
twocutes
Member Posts: 202
I want one. I dropped of the T@B for warranty work today at the dealer and saw a newer model with the retractable screen door, instead of the less than ideal Velcro screen. I thought I read about it on another thread, but don't remember which. The frame its in looks like it could be installed on the older T@Bs. Does anyone know?
Someone installed one - If I remember correctly they had to shorten the cabinet door under the fridge.
Thanks. I'm thinking if I emailed the Parts department, they could tell me if it would work in the clamshell (no frig inside).
Depending on the layout of your T@B you may have to make some modifications to the cabinets. I was able to install one in my 2012 with no modifications.
Sterling, VA -
Beth, I read yesterday that someone moved their cabinet doors over a bit, rather than cut 5/8" off of their cabinet door. Keep that in mind if you're told to trim a cabinet door.Verna, Columbus, IN
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
