Jensen TV inside the 2017 T@B320
huanvanho
huanvanho Member Posts: 48
edited October 2020 in Trailer & Towing
I have the standard Jensen TV inside my 2017 T@B320. When I perform an "auto-scan" to pick up local channels. I picked up ZERO channels. I replaced it with my home indoor Antenna, I picked up about 10 local channels. Does anyone have the same problems I have? I do not want to put home Antenna inside the Tab. I want to be able to use the standard factory Antenna.
Thanks for all comments
  • Bayliss
    Bayliss Member Posts: 1,517
    @huanvanho, if I am understanding your question correctly, there is no "standard factory antenna" for the television.  Although I cannot specifically speak to the design of your 2017 model, my 2019 (and others, as far as I have seen) has an external antenna coaxial connection/port.
    When I do not have cable hookup available, I use an external antenna connected to the outside connection.  There are options for using an antenna inside your trailer, or one that is position outside your trailer.  The only antenna installed by the factory is a small straight black antenna for the AM/FM radio.
    To get an idea of your options, I suggest that you use the search box (upper right of the forum pages screen) to enter the term "antenna" or "tv antenna" to get an idea of what T@B owners use to receive digital television channels.
    Greg & Marlene (Tucson, AZ)
  • huanvanho
    Thanks Bayliss. Now I understand. There is no factory Antenna.  I have a little external Antenna. I am assuming that is for FM radio. I have to purchase one like you said. Thanks again.
