Questions
emkay63
Member Posts: 2
Hi, I am new to the forums and have several questions. We are
contemplating buying an older used Tab (2004). It is in very good
condition but has no heat/AC and we are thinking of installing that if
we purchase. my questions would be what is the best way to go? A "mini
split", or something like what they have in the store here? Also where
to mount? I see in the store that they have the heat pump mounted to the
front hitch where the propane goes, but then where do you put the
propane? The Tab that we are looking at is the "U" configuration and has
the plastic box to cover the propane and/or battery. If we were to
install a "mini split" system could we attach the outside unit above
that box? What are our options? Any and all insight into this is greatly
appreciated... as is any encouragement/ discouragement in buying an
older camper.
Thanks!
Thanks!
If it were me, I would get the portable heat pump that the teardrop shop has. I would install the connectors on the street side , run duct work through the bench and the vents on the bench wall under the table, cool line towards the front, return closer to the back. Than just set the unit itself on the ground next to the trailer and hook it up & plug it in. That way it is not taking up any storage space and all the noise is outside were you won't hear it. I haven't seen one of them so I don't know how heavy they are, but they look like they are portable. That's my idea, maybe someone can come up with a better one. Hope you get your T@B.The HobbiT@B, 2015-L, towed by a2014 RAM C/V0
ok. thanks for both your input. i will consider them. to have someone else install sounds expensive so i will be saving a bit before that option!
