Found. A way to lower the spare tire on a 2021 NuCamp 320s Not so easy but...
hamrx
hamrx Member Posts: 16
Just picked up a new NuCamp T@B 320 s early November 2020.  going through a few things, what happens when I get a flat.  From past experiences, I have a long breaker bar and a 3/4 inch deep socket.  Oh, but wait.  How do I lower the spare tire.  After a lot of looking around I found where and lowered the tire, after removing the propane tank as my wrenches were to long(photo 1 and 2)  Photo 3 shows me trying to use the extension bars (2).  Didn't work.  Battery Box to high.  At least I figured out where it is, how to deal with it and now going to Tractor Supply or Home Depot for a long extension bar for my socket set.
Only if NuCamp  mounted the propane tank further left, Would also most probably allow for 2 tanks in the Box.  Still a tight fit.
Former 5th wheel and now T@B 320s owner. Amateur Radio Operator. Pulled by 2019 Ford Ranger Lariat 4 x 4
  • MarkAl
    MarkAl Member Posts: 510
    You should have gotten an adapter from nuCamp that is designed to go on the stabilizer crank end. Real easy though your Tank does make it look tougher. BTW, I didn't realize that's what the adapter was for and assembled a similar rachet / screw gun collection of stuff. Then someone on this forum told me the same thing... :)
    managed by VE Smart Network
  • ontheroad
    ontheroad Member Posts: 489
    edited November 2020
    I agree..they really need to move that tank a bit more to the left..we changed our dual 6 volt battery box and needed to get the propane tank moved over, now we have more storage in that beautiful new box.  Our full size spare tire wouldn't work underneath.
    Former 2017 T@G Max XL
    2021 T@B Boondock CS-S
    2018 Nissan Pathfinder
    Ontario, Canada
  • COHiker06
    COHiker06 Member Posts: 25
    $40 cordless drill, 3/8 drill to socket adapter will make fast work of what you're asking the ratchet to do. Works on the stabilizers too.
    2018 T@B400
    2019 Jeep GC 5.7L
    and two furry bed hogs
    Colorado
  • Dalehelman
    X2
    1. Hash  T@B Fun
  • COHiker06
    edited April 2021
    2018 T@B400
    2019 Jeep GC 5.7L
    Colorado
  • COHiker06
    I still carry my manual handles just in case but set the drill torque on its lowest setting and rock and roll.
    2018 T@B400
    2019 Jeep GC 5.7L
    Colorado
  • Steve_S
    Steve_S Member Posts: 9
    When I looked under the tongue of our newly acquired T@B 320 to put air in the spare and saw how it was mounted, I was baffled. Thanks so much for this great info because fir the there was nothing intuitive about how it works at all, and I’ve changed a lot of tires. Really appreciate the insight and sharing.
  • SLJ
    SLJ Member Posts: 666
    I moved the spare to the front on our 2021 320S.
    2021 T@B 320 S Boondock
    2025 KZ Sportsmen 130RD
    2025 Ford Ranger
    The Finger Lakes of New York
