sewer hose solution for cassette toilet
Tabnero
Member Posts: 251
I created a solution from a modified Thetford toilet spout cap and a Ridgid wet dry vacuum hose with adapter kit. Cut a hole in the cap and inserted and epoxy one shorten adaper. Cut a hole in the endcap for regular dump set up and inserted other shorten adaper. This will just be in a bag in the truck for those times where the cassette toilet dumping is regulated or the dump site has some difficulty for me
@Tabnero ; Like your solution, do have a few questions.
So the usage of this adapter solution would be:
a] Connect Yellow end to cassette (I didn't know cassette drain spout was threaded)
b] Connect Rigid vac hose to Yellow adapter and modified standard waste hose end cap
c] Connect standard waste hose end cap to standard Bayonet Elbow Fitting for connection to dumping 'hole'
d] Then dump Cassette to sewage system via this adapter-hose-adapter.
Nice
Any Tips on cutting the Bayonet end Cap as all I've seen have a turning handle molded-in.
Could you provide a correct (vs. my guess) diagram and BOM (bill of materials) for your solution.
the ridgid hose kit came with 2 adapters to fit the hose. You have the idea down. The yellow cap does not have an inner sleeve like the green one from the factory.
https://www.homedepot.com/p/RIDGID-2-1-2-in-x-7-ft-Dual-Flex-Tug-A-Long-Locking-Vacuum-Hose-for-RIDGID-Wet-Dry-Shop-Vacuums-LA2520/3056263251
