Just Some Paint
DougH
Member Posts: 1,110
A while back I had put gray vinyl planking down on the main area of the floor to reduce some of the feeling of soft spots.
Mostly worked, but it made the rear storage areas under and behind the main bench kind of odd looking with the brownish wood grain linoleum back there (I didn't bother to vinyl plank in the rear storage).
So today I put down several coats of a satin finish mildew proof paint in that whole area in an eggshell color (that somewhat matches the wallpaper). Kinda looks better, although time will tell if dirt shows up too easily. But we mostly just store baskets and blankets back there.
BEFORE:
AFTER:
I should really redo all the battery cables with custom lengths to look less cluttered... but in the passenger under-bench area I have two of the three AGM batteries, the Victron 100/30 charger, shunt for the battery monitor, thermostat for the vent fan built into the floor to get rid of inverter heat that may build up, wires leading off to front battery and basement heaters and rear camera, along with several size fuses.
BEFORE:
AFTER:
4
Brightens it up like you have a light in there!Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1
- 75 Teardrop Groups & Links
- 916 Tips & Tricks
