Pinched Adle reservoir overflow tube T@B400, 2019
jimcenname
Member Posts: 346
My 2019 T@B 400 has the Alde reservoir in the front of the cabin, drivers side in the porthole window compartment (since I have the 3-day fridge). While inspecting the Alde plumbing, under that area I notice the clear tube, intended for any overflow from the reservoir, was pinched behind a Alde plumbing pipe. My guess is that the tube is so taut it gets jammed behind the black pipe and gets pinched. I pulled the tubing free, as you can see in this photo but the pinch has taken a set. When you are in this area, maybe while inspecting your cool cat AC (which is just below the are in this photo) you may want to see if your tube is pinched. If you have your reservoir in the wardrobe, obviously this doesn't apply.
2019 T@B400
Southern California
Full-timer since 2019
Southern California
