Alde 3010 Control Panel is not working
Lynnlee
Member Posts: 11
I'm prepping my 2016 TAB 320 S for camping. Everything is working (e.g., 12v lights and fan, shore power, propane), except when I attempt to turn on the Alde (3010 control panel) I find a dark screen. I checked 12v fuses; they are OK. Then found (-) glass fuse blown on top of Alde. Replaced both fuses. Control Panel still not showing any life. I turned the 12v power to panel off and on. Still no sign of life in panel.
What is going on? Do I need a new Control Panel, as the local NuCamp Service person (via a phone conversation) indicated was likely.
Or, is the blown fuse trying to indicate something. I do not have a surge protector on my shore electrical line, but have gotten advice from forum members of what to buy early this week! Thank you, and perhaps I'm too late and have damaged my control panel.
Your help is appreciated. Was hoping to get out this weekend, but must solve this before my first camping of the year.
2016 T@B 320-S, 2020 Subaru Outback Limited XT
2024 T@B 320 S, 2023 Toyota Highlander Hybrid LE
I've been through a similar trial, figuring out that I needed to replace an Alde fuse.
How is your battery?
Does the Alde start on propane?
I'm not sure if the Alde needs battery to start on 12V electricity, but it does need battery to start on propane.2014 T@B 320 S "Sunny" - 2015 Toyota Sienna LE - British Columbia, Canada -
Check out this thread: https://tab-rv.vanillacommunity.com/discussion/2794/alde-touch-screen-wont-come-on/p1Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
With your help I've ordered a surge protector and expect to replace the control panel on Monday. That should help! Thank you!
2024 T@B 320 S, 2023 Toyota Highlander Hybrid LE -
@Lynnlee - although you may do this already, be sure to turn the Alde off before disconnecting from shorepower. This way you avoid a potential power surge that may blow an Alde fuse the next time you plug into shorepower.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
- 916 Introductions
- 72 Teardrop Groups & Links
