Norcold igniter not getting spark on propane setting - Resolved
TRob
Member Posts: 54
I tried to run the fridge on propane for the first time. We have a 2021 Tab 400 BD with the three way fridge.
It gave me error code 3. A little searching on here and I found some hints to diagnose. I took the little cover off the ignitor and setup my camera to video it while I changed the setting to propane. When I reviewed the video I heard three clicks from that area but there was no spark.
Here is a picture.
Any suggestions on what to do next?
Here is a picture.
Troy / 2020 Jeep Gladiator Rubicon / 2021 Tab 400 BD / Sarasota, FL
I had the same issue a couple of years ago. There are 3 fuses on top of the fridge, but you have to lift the stove top to access. Not a big deal. There are 4 screws under plastic caps in each corner that need to be loosened. Then just lift the front of the stove. Here is a photo. As I remember one of those fuses had failed.
- Hash T@B Fun
Were you able to light your stove? Sometimes it's best to turn on the stove and get the air out of the line. Once the stove is lit let it run for a minute or so, then try lighting the frig.Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ0
Dalehelman said:I had the same issue a couple of years ago. There are 3 fuses on top of the fridge, but you have to lift the stove top to access. Not a big deal. There are 4 screws under plastic caps in each corner that need to be loosened. Then just lift the front of the stove. Here is a photo. As I remember one of those fuses had failed.
Thanks. I think you may have a different model though. The three way in my model is across from the stovetop by the bathroom.Troy / 2020 Jeep Gladiator Rubicon / 2021 Tab 400 BD / Sarasota, FL1 -
The stove is working. I'll run it a bit more just to be certain.Michigan_Mike said:Were you able to light your stove? Sometimes it's best to turn on the stove and get the air out of the line. Once the stove is lit let it run for a minute or so, then try lighting the frig.
I'm thinking that it's possibly a problem generating the spark. It sounds like it's trying to spark but I don't see it making one.Troy / 2020 Jeep Gladiator Rubicon / 2021 Tab 400 BD / Sarasota, FL0 -
With the obvious cautionary considerations:
You could try lighting the burner with a butane lighter. If it fires off it will likely go out after a few seconds as the onboard sensor won't detect that and the flame will automatically shut down for safety reasons. That tells you it's getting LP (e.g. not the valve), and that the issues may be with the spark electrode or the board itself, assuming the fuses are in good order (meaning you're getting 12v current to the spark electrode).
Be sure the gap at the spark electrode is from 1/16" to no more than 1/8" from its ground. Too close or too far, no joy.2020 T@B 400 "OTTO" (build date 08/19)
San Diego, CA
www.airbossone.com
https://fineartamerica.com/profiles/owen-ashurst/shop0 -
Problem solved! The igniter was too far from the ground. It's working now. Thanks!Troy / 2020 Jeep Gladiator Rubicon / 2021 Tab 400 BD / Sarasota, FL1
Cool!
San Diego, CA
www.airbossone.com
