Pulling a T@B320
huanvanho
I am towing my 2017 T@B320 with my Infiniti QX60 AWD. Every time I step on the Brake, the T@B surged... It does not make me feel safe. I have a feeling the T@B may run away from my SUV... I checked the hitch ball and it was latched and locked..
Please shares your comments? Is that a normal? Should I have the dealer to check out the trailer?
Thank you
Thank you
What kind of brake controller are you using? Maybe it needs adjusting?2019 T@B 320 S | 2019 Subaru Ascent1
@huanvanho - what do you mean by surge? Have you checked the TaB brakes? Any noises?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Sounds like brake controller isn’t adjusted properly. Did you follow the owners manual setup?2022 TAB 400 Boondock, 2019 Toyota Tacoma Sport 4x4
Odessa, Fl.
How do I adjust brake controller? Where is it at? I did not know it exists. Please show me how.. Thanks1
The TaB has electric brakes and you need a brake controller to set and operate the brakes.If it feels like the trailer does not want to stop when you brake, you need to use the electric brakes that are built in to the TaB. You need to buy and install a proportional brake controller. I think you are unsafe and are at risk until you install the controller and use the TaB brakes.
Call your dealer and have them install a controller.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1 -
Thanks. I understand now... Will call the dealer to check it out...0
We just got the Curt Echo wireless controller, super simple (just plug in, really) and no modifications to vehicle, works from your Wireless app on your phone. If I had known how easy it was I would not have bought at the dealer…
CURT 51180 Echo Mobile Electric Trailer Brake Controller with Bluetooth-Enabled Smartphone Connection, Proportional https://www.amazon.com/dp/B07JQ99SDD/ref=cm_sw_r_cp_api_glt_fabc_NQKFPNMCHJM7TFC2PD9B
2021 T@B Boondock 320S | 2021 Toyota Tacoma SR5 V60
- 144 Events & News
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
