Replacement Reading Lights
DougHDougH Member Posts: 1,110
edited March 2021 in Modifications & Upgrades
The plastic toggle switches for the back reading lights eventually started going out.  So I picked up what I think a couple other folks on the forum have gone with...
Thalassa Blue Night Light / Dimmable Warm White Light / USB Port  $50 for the pair.
https://www.amazon.com/dp/B07JNLCFQL
A bit pricier than many 12V lamps on Amazon, but these were the closest to original base size so I figured no new screw holes or mounting plates. That turned out to be correct.
[1] Unscrewed two Roberson head screws holding old reading light, [2] clipped wires right at lamp connection, [3] slipped included new mounting plate over wires, [4] soldered white camper wire to black wire of new lamp, and black camper wire to red wire of new lamp, [5] screwed plate in with existing holes and new provided phillips screws, [6] put lamps at an angle with USB port facing down and towards center of bench, [7] tightened down the set screw to keep lamps attached to mounting plate. Ten minutes total installation time, and two more handy USB ports. Only 1.4W and they remember the mode and dimming level. Press once for blue night light, a second time for white light, and hold finger on touch sensitive area to gradually or dim the bulb.
