Kitchen sink glass top doesn't fully close
Has anyone else run into this problem and if so how did you fix it? The glass lid on our sink on our 2021 TAB400 doesn't close properly. The problem is that the right hand screw that holds the glass to the hinge fouls on the faucet. See picture. I have contacted nuCamp but no answer yet. I am concerned that the glass may break while travelling.
  • falcon1970
    falcon1970 Member Posts: 758
    It is hard to tell from the photo, but it looks like that screw head is standing a bit proud.  Is that bolt fully tightened?
  • rhyno
    rhyno Member Posts: 393
    edited April 2021
    Ours did the same when we first got our tab. The fix was to loosen then rotate the faucet assembly clockwise slightly until the lid was able to fully close. Then I snugged the faucet nut back down to keep it in the new position.
  • jimcenname
    jimcenname Member Posts: 346
    I found the lid to be in the way most of the time and removed it.
    2019 T@B400
    Southern California
    Full-timer since 2019
  • Dalehelman
    Sounds like an easy fix.
    1. Hash  T@B Fun
  • Vinney
    Vinney Member Posts: 7
    Thank you everyone. I tried the “twist the faucet clockwise” solution and found that it moved quite easily. I then tightened the plastic nut underneath the faucet and now the lid closes fully.
