Kitchen sink glass top doesn't fully close
Vinney
Member Posts: 7
Has anyone else run into this problem and if so how did you fix it? The glass lid on our sink on our 2021 TAB400 doesn't close properly. The problem is that the right hand screw that holds the glass to the hinge fouls on the faucet. See picture. I have contacted nuCamp but no answer yet. I am concerned that the glass may break while travelling.
It is hard to tell from the photo, but it looks like that screw head is standing a bit proud. Is that bolt fully tightened?0
Ours did the same when we first got our tab. The fix was to loosen then rotate the faucet assembly clockwise slightly until the lid was able to fully close. Then I snugged the faucet nut back down to keep it in the new position.2021 T@B 400 BD, 2021 Lexus GX 460, Kansas City MO1
I found the lid to be in the way most of the time and removed it.
2019 T@B400
Southern California
Full-timer since 20190 -
Sounds like an easy fix.rhyno said:Ours did the same when we first got our tab. The fix was to loosen then rotate the faucet assembly clockwise slightly until the lid was able to fully close. Then I snugged the faucet nut back down to keep it in the new position.- Hash T@B Fun
Thank you everyone. I tried the “twist the faucet clockwise” solution and found that it moved quite easily. I then tightened the plastic nut underneath the faucet and now the lid closes fully.1
- 920 Introductions
- 75 Teardrop Groups & Links
- 916 Tips & Tricks
- 54 üCamp Rally - News & Information
