Remove cabinet door?
2017 CS-S
I would like to remove the door on the small cabinet under the front bench, directly to your right hand when you open the T@b door. I don't see a hinge pin to remove.  Do I just remove the screws holding the hinges to the cabinet?  Thx
2017 CS-S Max (Silver & Yellow), TV 2019 Ram 1500
Camping under the Big Sky
    I don't believe there is any removeable pin in those spring hinges, but you should be able to just unscrew them from either the door side or the frame side. I've done it with other cabinets and don't recall any particular challenges.
  • gophergrad
    gophergrad Member Posts: 115
    Thanks @ScottG
    I couldn't believe it was that easy! One screw per hung.
