Nautilus P3 - 2 questions
geoB
Member Posts: 111
For a 2021 T@B 400 Boondock, two hopefully easy to answer questions:
- What is the proper name for the port-side compartment that contains the Nautilus P3 panel?
- On the accompanying photo, what function is served by the valves pointed to by red arrows? I can find no reference to them.
2020 Toyota Highlander + 2021 T@B 400 BD
Truckee, CA, expat, now driving out of Reno
The arrows in your pic are pointing at the hot/cold low point drain valves.2021 T@B 400 BD, 2021 Lexus GX 460, Kansas City MO
That's what I was thinking, even though there appears to be identical valves under the bed. The Nautilus valves are substantially more convenient.
Truckee, CA, expat, now driving out of Reno -
The valves under the bed are for draining the Alde system.2021 T@B 400 BD, 2021 Lexus GX 460, Kansas City MO
More specifically, the Alde and Flo Hot-water tanks. You need to open the galley tap and shower taps to get the lines fully drained.cheers2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.
- 916 Introductions
- 72 Teardrop Groups & Links
