dragonsdofly said:@DenverJaguar, you didn't say what year trailer you have. In our 2017, we have a 2" topper and we use king sized fitted and top sheets. The king size allows a huge 9" - 12" overlap under the topper. We have never had the fitted sheet pop off with so much overage of fabric underneath. Second question, a 2" topper and both fitted and flat sheets easily roll up and fit behind the sofa seat. Again, we have a 2017 and measurements may vary significantly. We use 4 straps that I sewed to keep the topper and sheets together, jelly roll style, which keeps everything nice and neat behind the sofa back. It's also easier to stash into and recover from that position with straps on. Good luck. -Denise
I have a 2022 on order. So the king sized sheets don't come out from under the topper? I am not handy with a sewing machine or thread and needle, so I won't be able to add straps, but I like that idea! And thank you for confirming it fits behind the cushions. I think the 2022 is pretty much the same behind that area as your 2017 model.
Yes @DenverJaguar, it fits rolled up behind the rear seat, which is why we switched to it from what we were using. Our other pads were too bulky. These roll up nicely and are super comfy, like the pillow top of a really nice mattress in your house.DenverJaguar said:@TheBellHop Are you able to roll it up and fit it behind the rear cushions? I'm not sure how much space is back there or if this is possible. I see the sheets have a minimum mattress thickness of 4 inches, so if I got the 2 inch topper, the sheets would still be too big.
