Removing front bezel on Jensen cube?
Hi all!
Does anyone know how to remove the front bezel on the Jensen cube?
I want to gain access to the power lead so i can switch it and its annoying display off at night.
Thank you!
Brent
2021 Tab 320s Boondock-2016 Toyota Venza V6
Toronto, Canada
  • Tabaz
    Tabaz Member Posts: 2,420
    Not sure which model you have, so here is a link to the Jensen installation manuals.  Hope this helps.
    https://jensenmobile.com/user-manuals.html
    2016 Outback 320
    I don't know if the new models differ, but my entire unit could be removed from the cabinet after removing four screws on the face. A wiring harness in the back of the unit included the main power line.
  • CanadianTabber
    CanadianTabber Member Posts: 148
    The screws are likely under the bezel..here is what it looks like.
    Toronto, Canada
  • Verna
    Verna Member Posts: 6,876
    I would try a plastic putty knife to lightly pry the front bezel off. Expect to find Robertson or square drive screws under the bezel.
    I intend to put an inline switch next to the Jenson as I don’t use it. Less phantom draws on the battery system and no light from the Jensen at night.
  • CanadianTabber
    I will try that Verna..thank you!
    Brent
    Toronto, Canada
  • rhyno
    rhyno Member Posts: 393
    FYI you could dim the Jensen cube to zero then toggle the display on and off by tapping the power button. That's what we are doing until I get the time to install a power switch to kill the phantom draw off the batteries.
  • CanadianTabber
    I did try to do that rhyno, put couldnt get it to dim fully...will try again but like you, I want to kill the draw.
    Brent
    Toronto, Canada
  • CanadianTabber
    Success!..i was able to gently pry off the bezel quite easily and remove the 4 Robertson screws to take out the unit.
    I will be putting a small toggle switch on the panel to the left of the radio with the toggle out of sight in the small cubby there...thanks for all the help everyone!
    Brent
    Toronto, Canada
    Yeah, that's way different from mine. Glad you got it figured out in either case!
  • CanadianTabber
    Btw, here is the manual
    Toronto, Canada
  • Yoshi_TAB
    Yoshi_TAB Member Posts: 597
    Hi,
    Do you have a picture of the switch or brand/part number you used?  I also would like to have the light completely off at night.  Thank you
    2025 360 CS
    Southern Maryland
  • CanadianTabber
    Yoshi_TAB, I used a toggle switch i had kicking around.
    I drilled a hole the size of the switch shank and inserted it from behind with wires already attached. Because the switch shank was not long enough, i just epoxied it in, cut the red wire and crimped the switch wires to the two red wires...simple but effective!
    Here is the pics🙂
    Toronto, Canada
