Accessing Roof/Sidewall Joint Seals
I'm curious as to how 400 owners (and I guess 320 owners) are able to do their seal checks with the decorative plastic trim pieces in the way of the roof/sidewall joints? Are those plastic pieces easily removable?
2021 400 BD
2020 Tacoma TRD Off-Road
  • TabulatingTabulating Member Posts: 86
    I was  looking at mine early today. I have the same question.  It appears the vinyl is underneath at least some of the sealing compound around the windows and some of that vinyl is a little loose near the windows.
    2018 T@b 400  towed by a 2012 JKU
  • manyman297manyman297 Member Posts: 1,430
    I was referring to the junction between the roof and the sidewalls (underneath the corner trim that runs from the front to the back of the trailer).
    But yeah, I noticed the vinyl decals on the door windows run under the seal which I know they changed on the round windows (there's a 1/4" gap so the decals don't run under the windows and cause leaks if the vinyl adhesives gives out.
    2021 400 BD
