tire size
Bee
Member Posts: 11
Complete noobies here... We bought our very first TT, a 2015 T@B in great condition and a reasonable price. The tires, however, are apparently original factory tires dated 2014. I am considering changing these to the GY Endurance tires shortly due to age. The owners' manual states that the factory tires are ST205/75R14 and gives tire pressures for them. Our T@B has same brand but ST205/75R15. My noobie question is -
what are the pros and cons of having the larger tires? Is there any reason to go back to 14"?
Big Welcome to the T@B Family.
In general the 320 model trailers have 14-inch wheels on the 'standard axle' models and 15-inch wheels on the [old name] Outback Edition now called a Boondock. The Outback/Boondock have a higher pitch torsion axle that provides additional ground clearance.
Believe the 15-inch tires (R15) will not fit on a standard axle trailer as the tires will rub.
If your trailer has R15 tires installed now you should go ahead and get R15 replacements; IMHO.To change to R14 would require purchasing new wheels as well as tires.{manual information is most likely based on 'standard axle' trailer model}'18 320 S, pitched axle, 3020HE; PNW basedTV: '17 Colorado V6 Z71 4x4, Tow Package, GM Brake Controller
Adventures: 58 Nights: 405 Towing Miles 50,1800
- 957 Air Conditioning & Refrigeration
- 922 Introductions
- 410 Service/Maintenance & Recall Notices
- 75 Teardrop Groups & Links
- 919 Tips & Tricks
