2021 320 S BD - Rewiring all things entertainment, adding 12V switch bank, adding 12V Blu-ray player, digital battery meter, and USB C charging ports. Everything will be on it's own switch so they won't suck the life out of the battery. Way it should be in a boondock version. Next - adding an external antenna for over the air digital TV.
2021 T@B 320 S Boondock
2023 Ford Maverick XLT
The Finger Lakes of New York
2 ·
Guess I'd also say nuCamp uses some discretion in certain areas to keep costs down.
San Diego, CA
www.airbossone.com
Switches from left to right: Overhead lights, USB chargers, Jensen Stereo, Blu-Ray player, and TV. Digital Battery meter is on with toggle switch. None will draw battery power when switch is off. Switch LED is only lit when on and I can disable or dim any of them I choose.
Thanks!
Brent
Toronto, Canada
Nice job on your panel. I have a few of my switches done. Plus unhooked step light and removed the clamshell safety solenoid. you can also see my IR extender which extends the IR remote from outside the clamshell.
2021 CS-S - Enjoying the new layout
2011 Outback 3.6r
